Group: DynoMotion Message: 5339 From: mattbsemail Date: 6/26/2012
Subject: Best Encoder output and voltage for KFlop?
I found this encoder and it is a direct drop in to replace my resolvers. What is the best output and voltage for the KFlop?
Output Options:
01 = TTL Output
02 = RS422A Line Driver
03 = OL 7272 5-26 VDC Line Driver
Voltage Options:
5 VDC +/- 5%
5 - 26 VDC
http://www.quantumdev.com/pdf/qd110.pdf
Group: DynoMotion Message: 5340 From: Michael Niksch Date: 6/26/2012
Subject: Re: Best Encoder output and voltage for KFlop?
From my experience .....ttl output, 5v.  I believe that's the standard.
Mike
Output Options:
01 = TTL Output
Voltage Options:
5 VDC +/- 5%
5 - 26 VDC
Group: DynoMotion Message: 5345 From: Tom Kerekes Date: 6/26/2012
Hi Matt,
I would choose Option 02.   That is a differential signal.  Differential signals are much less susceptible to noise.  You could connect it to differential inputs or single ended inputs by just using one of the signals.  KFLOP only has single ended inputs.  But in the future it would be available to connect to differential inputs on Kanalog or SnapAmp.  There are also low cost (~$15) cables with differential to single ended receivers built in.
Group: DynoMotion Message: 5350 From: mattbsemail Date: 6/27/2012
Thanks for the info Mike!
> Mike
> > Output Options:
> > 01 = TTL Output
> > Voltage Options:
> > 5 VDC +/- 5%
> > 5 - 26 VDC
Group: DynoMotion Message: 5351 From: michaelthomasn Date: 6/27/2012
Matt,
You're welcome for the poor info.....lol. Sorry. My encoders are TTL and differential. I guess those are different.
> Hi Matt,
> From: mattbsemail <mattbsemail@...>
> Sent: Tuesday, June 26, 2012 5:18 PM
> Subject: [DynoMotion] Best Encoder output and voltage for KFlop?
> Output Options:
> 01 = TTL Output
> Voltage Options:
> 5 VDC +/- 5%
> 5 - 26 VDC
Group: DynoMotion Message: 5352 From: mattbsemail Date: 6/27/2012
I have the Kanalog mounted to the KFlop so stick with option 2?
> Hi Matt,
> Output Options:
> 01 = TTL Output
> Voltage Options:
> 5 VDC +/- 5%
> 5 - 26 VDC
Group: DynoMotion Message: 5353 From: Tom Kerekes Date: 6/27/2012
Yes
